Home › Forums › Usage › S Parameter or other graph export?
  • #8561
    efz
      Hello
      I have been trying to do this forever. The instructions  in the documentation do not work. There is no copy or export when right clicking on a graph.  Neither in content. I am sure I am doing something wrong
      Thank you
      Exporting the data of one variable is best done directly from its graph in a diagram. Right-click on the graph and choose:
      Graph to Clipboard – The data is now in the system clipboard and can be inserted into a tabular calculator or into a text editor. The format is: Independet variable in the first columns, magnitude of dependet variable in the next column and phase in degree of the dependent variable in the last column.
      Export to CSV… – Creates a CSV file and put the data into it. The format is: Independet variable in the first columns, real part of dependet variable in the next column and imaginary part of the dependent variable in the last column.
      Qucs data files can be converted to touchstone files by using the right mouse button in the content tab. It is also possible to convert Touchstone files to Qucs data files this way.
      #8584
        works for me.
