Home › Forums › Usage › S-parameter simulation AC power source always at +10 dBm
  • #8874
    rebakker
      Within a S-parameter simulation the ‘AC power source’ is used as the source. This ‘AC power source’ has a parameter P which controls the available AC power. The P parameter is 0 dBm by default, but changing it has no effect on the simulation results. The output level remains at +10 dBm. Not even at 0 dBm.
      Why is that?
      Kind regards,
      Rene
      #8876
        S-Parameters are linear, so the power level has no influence. I suspect, a power level is not even defined / needed by the solver.
        How did you measure the power? The voltage and current probes do not work with a S-Paramter-Block active
        #8877
        rebakker
          The following schematic shows P=0 dBm but the measured level in the diagram is 10 dBm.
          So why is it always at +10 dBm?
          #8879
            According to F1 help:
            dBm(x,Z)
            convert voltage across impedance Z into (active) power in dBm (parameter Z is optional, default 50)
            dBm() should be applied to voltages. S-parameters are dimensionless voltage ratios.
            S21 is 1 for such a circuit. An impedance of 50 Ohm and 1 V_peak would dissipate 1/100 W of power. Equals +10dBm
