Home › Forums › Development › Set “Open dpl after sim” default: no This topic has 2 replies, 2 voices, and was last updated 3 years, 2 months ago by Carsten. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts 6. December 2022 at 20:32 #6860 CarstenParticipant I suggest that for a new project, the checkbox “open data display after sim” should be unchecked by default. Its the first thing I do when creating a new project. This topic was modified 1 year, 9 months ago by maelh. Reason: Convert all remaining http links to https links 10. December 2022 at 9:49 #6872 QucsStudioKeymaster Just a tip: If a new schematic is drawn and you start the simulation before saving the file, then the schematic is automatically chosen as the data display. 11. December 2022 at 23:13 #6884 CarstenParticipant Indeed. I just tried. BTW. The content of the fields “Data Display” and “Data set” are imho not intuitive *.dpl seems to mean <schematic-name>.dpl and in the case, that you described, the field stays just empty. I don’t have a better solution though This reply was modified 1 year, 9 months ago by maelh. Reason: Convert all remaining http links to https links Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic.
