Home › Forums › Development › Behavior of InitialDC in Transient Simulation inconsistent with explicit IC
  • #7483
    drahnoel
      I am looking at transient simulations with initialDC=yes. This setting enables calculation of initial conditions based on an implicit DC simulation. However, I find the treatment of explicit initial conditions inconsistent. Currently, explicit conditions are not considered during the initial DC simulation, but then overrule the implicitly derived ones. See attachment.
      I propose two more consistent approaches:
      Proposal A:
      With initialDC=yes, explicit initial conditions are always ignored and overruled by the implicit ones derived from the DC solution.
      Proposal B:
      With initialDC=yes, explicit initial conditions are respected during the initial DC simulation. Capacitors with explicit conditions are replaced with voltage sources, coils replaced with current sources.
      #7505
        Even though your thoughts make sense, I don’t think that the current behavior is inconsistent. Proposal A is not bad, but I still find the current solution the best one.
        #7511
        drahnoel
          Ok.
          There are some components, where one needs to use initialDC=yes, because they have no initial conditions fields. Example: Diode. (With initial DC=0, they always start with 0V at t=0)
          However, I want to have different initial conditions as initialDC=yes calculates. So, what I do is to force the voltages to the desired initial conditions using a voltage source. To make the voltage source not affect transient simulation, I add a 1H inductance in series. This way I emulate the InitCond element of ADS.
          This is the workaround I am successfully using at the moment.
