Home › Forums › Development › Exporting S-parameters
- This topic has 10 replies, 4 voices, and was last updated 1 year, 8 months ago by
efz.
31. January 2021 at 9:50 #702
Maybe its just me not reading manual carefully enough, but I’ve been trying to export S-parameter file from my 3-port simulation (in Touchstone format) without success.
I wonder if this is possible at all with current version ?
31. January 2021 at 10:03 #703and oh, this is very embarrassing because just after posting this I figured it out 🙂
Just in case anyone else is wondering, this is very logical and easy, data is in the Dataset folder and can be exported by right clicking the dataset and selecting “Export to SnP”. As said, logical and easy…
4. July 2021 at 22:43 #992Hi,
I managed to do S2P for Notch_Filter from Simulation_EM_field_prj like this, but I get this for Interdigital_filter:6. July 2021 at 20:26 #997That is, when simulating from pcb, while export to SNP does not work?
And do you need to do SnP manually in this case via Export to CSV?9. June 2022 at 14:33 #3045Hello,
I would like to export S-Parameters … however in the “Inhalt” (Content) tab I do not find the triangle shaped symbols to expand it. Any clicking has no effect. Any idea how to fix it? “Datensätze” is the German “dataset” that I need to expand.
This reply was modified 1 year, 10 months ago by
9. June 2022 at 15:55 #3046Never mind, now it works. I had to save the schematic file in the project folder.
19. July 2024 at 22:46 #8562hello None of this is working for me.. trying to export S parameters. Been trying everything.
Help please!
thank you
19. July 2024 at 23:19 #8563Finally I have been able to copy the data from a Smith chart graph and paste it into notepad. I can now edit it and create an S parameter file. But this will only work for a 1 port as the smith has the Re + Im.
This wont work for Full 2 port S parameter data!
thanks
22. July 2024 at 16:20 #8564There is no right click on dataset. Still trying to export S parameters! There is only the
“dataset” nothing in it.Attachments:
22. July 2024 at 16:22 #8566I am trying to do the same thing. I dont know what you mean by “save the schematic file in the project folder.” all the files for schematic and data are in the same folder.
thanks
22. July 2024 at 16:29 #8567never mind finally figured it out also!
