Home › Forums › Development › Using data in equation from different *.dat files
  • #8572
    Didier CELI
      Dear QucsStudio developer(s)
      As you know I use QucsStudio for model parameter extractions. It is a fantastic tool for that. I would like to use in equation data coming from different *.dat files.
      That works very well in table and plot, but not in equation. I have the following error message
      ‘Error in ‘Test’: Operand expected in equation “‘strobe_OP’:CPIi + ‘strobe_OP’:CPxi”
      I use QucsStudio v3.3.2 because of issue with version  4.3.2 (see bug reports ‘Voltage of labeled node (node.V) not recognized in equation’).
      –> Is it possible to add the ability to use in equation data coming from different *.dat files?
