Home › Forums › Development › Version 5.8 released
- This topic has 7 replies, 5 voices, and was last updated 9 months ago by
Andy_JP.
23. November 2024 at 10:04 #8824
The long-awaited, new version is available in the download section. Note that the application name changed to uSimmics in order to clearly distinguish it from the Qucs projects. This is a major release with many, many improvements, new features and bugfixes.
And as always: Thanks a lot to all supporters! This release would not have been possible without you.
Please consider to help keeping this project alive by supporting it.23. November 2024 at 11:23 #8826Congratulations and thanks a lot for your effort!
Is ther a change log we could check somewhere?
23. November 2024 at 14:56 #8827Thank you very much for making this possible!
Changelog would be nice.
Just saw, Qucs is not using another pcb layout tool.
23. November 2024 at 15:26 #8828Thank you very much for all the effort you have put into uSimmics!
Warm regards,
Daniel.
23. November 2024 at 16:24 #8831function rtoz() is no longer defined. Is that a bug or intentional?
I remember using it once.
ztor() still exists
1. December 2024 at 16:17 #8859Yes, this is intentional. stoz() does the same job, so please use this function. ztor() is still needed and thus, does still exist.
3. March 2025 at 16:57 #8907Hi “QucsStudio”,
uSimmics v5.8 really made a major step in usability:
- Nice face lift of the icons:
- Frequency engineering units in graphs:
How long I was looking for the engineering frequency units.
It really improves the readability a lot!
Thank you very much, “QucsStudio”!
Daniel.
3. July 2025 at 6:54 #8996I have a question about some older bugs and limitations, were they fized or not?
1. It was not possible using complex power source impedance. Even when defined with “i”, only its real part was treated. Can we use complex sources(loads) now? It is essential when modelling real devices, like antenna frontends. (have you ever seen an antenna with wideband purely real impedance? I guess, only in 1st course textbook)
2. Since it is often essential matching to real measured load/source, there was a feature in [S-parameters] block, called “ComplexZ”. Ideally, it should have converted the simulated fixed-Z port into the measured frequency dependent complex impedance port reprezentation, with the VNA-acquired data.
But it was not working. I mean, people, including developers believed it worked, but it was producing garbage data. I checked it with Agilent-ADS, and real life components many times. In V.4 it was crippled.
Was it fixed in V.5?
